application not found
Adithya2211
Hey I'm using Xperia z3D6653 with lolipop.I send some apps to my SD SD. And they got deleted Saying"application not found". I saw it one forum there was a answer that to delete. Android secure file. So I deleted it after that apps did not delete. But after few days again apps are missing. So I tried to delete the android secure file(as there was) and there was a error code(sorry I can't remember the code) and saying the file not already exist. I restart the phone several times and useless. Then I format my SD. now I can't download previously downloaded apps which are deleted. Saying unsuccessful -501 error code. I went to the manu and saw list of blue colour icons which are cannot open. I guess that is the problem? And I can't deleted the blue coloured icons. Plz tell me a solution. Is it the problem with the sd or?
5 REPLIES 5
Thommo
Genius
Some apps although can be transferred to SD may not be compatible with running from an SD card and thus will be a blank icon or simply won't work or stop so I think in this situation that this is what you have encountered - To fix you could try transferring the apps back or you may just have to bite the bullet and do a factory reset saving what you need to 1st
profile.country.RO.title
_alexdon_
This is a result of being able to move apps to SD. Please see this:
/t5/Software-Updates/Apps-moved-to-SD-card-still-reserve-space-in-internal-storage/m-p/956195#U95619...
alexdon
Adithya2211
I cant install the previously install apps which are deleted. It says a code -501
Adithya2211
I cant install my previously installed apps which are deleted after I send th to the sd. And there are blue icons in the manu I can't remove them also...
Rickard
If you still see these apps under Settings -> Apps, try uninstalling them from there and see if that helps.
If you don't have them there, go to Settings -> Apps -> All -> Xperia Home -> Clear data -> OK and then restart the phone. But please note that this will reset your home screen to default settings.
