Answer machine problem after update z2
Shaunmc
Hi, after update to 5.0.2 the answer machine on my z2 will not switch off if I answer a call. This is frustrating as now when I am 20 seconds into a call the answer machine cuts in, unlike before. Is this just the new way this works with this version, or is it a phone issue?
Rickard
I'm afraid this is a software issue with the latest version. The issue may occour if you enable smart call handling or if you answer a call by pressing the answering button on a headset. The issue will be fixed in the next software update.
6 REPLIES 6
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Shaunmc
Hi, yes I tried that but still the same. So maybe a phone issue then?
murtaza1
mine working very normal. may be you try formating and using it
Shaunmc
Ok, I've now re-set the phone, done a full software repair and still have the same problem. I have noticed that if I answer a call with the screen swipe it is ok, but if I answer with motion the answer machine comes on after the set time.
Paddymcrico
Hey,
I have a Z3 compact. Same thing.
Answering machine on - answer with "old?" style swipe - no problem - full conversation.
Answering machine on -   answer with motion (up to your ear) - cuts off the wife after 10 seconds (Sometimes this is good!!!! ... lol Winking_Face )
But hey, Sony!!!! surely this can get sorted. Throw me a bag of money and I'll give it a go!
Rickard
