Alarm silenced after 0 minutes?? How? Why?
PityTheFool
For the second time in 2 days, I woke up an hour or so late to find a notification saying "Alarm silenced after 0 minutes"
My phone isn't rooted or anything.
Still running factory software.
And no new application were installed recently.
I checked alarm settings, everything was as I had set it earlier.
Could someone please look into this issue because this is the only alarm clock I've been using for quite a while now and if the alarm auto silences on an important day, I'm screwed
Jake-SonyXperia
Hi PityTheFool,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
You could try clearing out the Alarm application, this would atleast make sure there is no bad data causing issues with the snooze event.
Menu > Settings > Apps > all > Alarm > clear data.
You will need to do the alarms again however
9 REPLIES 9
Thommo
Genius
Do you have a Smartband etc which you wear all the time and is it at all possible whilst waking up you turned it off and went back to sleep - You wouldn'd be the only one that has
Jake-SonyXperia
Hi PityTheFool,
PityTheFool
@Thommo
No I don't use a smartband or any such accessory
PityTheFool
@jake
Thanks
Will give it a shot and let you know Slightly_smiling_Face
PityTheFool
@jake
The alarm app is not shown in the apps list in settings, could that be an issue?
I'm not sure if it was there before since I've never needed to clear alarm data
Although, Clock is shown.. Do I clear data for that?
Thommo
Genius
Yes Clock is Alarm and stopwatch etc
PityTheFool
Clearing the app data seems to have solved the problem for now..
How can I make sure it doesn't happen again?
Will I have to periodically clear the app data?
PityTheFool
Thank you guys for the help Slightly_smiling_Face
Jake-SonyXperia
Not a problem, glad we could help Slightly_smiling_Face
