About charging, need help.
EqiNox1
Hello everyone. I bought Xperia Z3 a few months ago. I watched all videos about Xperia Z3 on YouTube. And about battery life, everyone says " Up to 2 day battery life. ". First 3-4 month was good, but now its maximum 10-11 hours. What about 48 hours ?
Look at this;
21:03 ( 09:03 PM )
" Low battery mode has been activated. (15%) "
21:05 ( 09:05 PM )
Its 4% now....
How can I solve this problem ?
@EqiNox
Thanks for the screenshots, as you can see your phone its awake most of the time and WiFi its on all the time, things to do, charge the phone 100% > boot on safe mode > use it on safe mode for couple of hours and compare if you experience the same battery drain.
Also, the screen was on for almost 3 hours, that will drain quite a bit of battery.
11 REPLIES 11
@EqiNox
That doesn't tell us much
We'll need more info to better assist you
charge the phone 100% use it as you normally would then once the battery reaches 10%
settings > power management > battery > take screenshots of:
1. the list
2. tap on the graph and take a screenshot
3. back > tap on the top 4 items on the list > take a screenshot of each
post them all here or upload the screenshots to box or dropbox or google drive or etc and post the link
@EqiNox
EqiNox1
Allright, thanks for the assist. I will try that "safe mode" thing, and I will visit here tomorrow.
@EqiNox
If you experience the same issue, repair the phone with PCC, it should smooth things out
software repair
PC Companion (PCC)
Bridge (for Mac)
@EqiNox
As for your other question on marshmallow, no one knows.
EqiNox1
Oh okay then
@EqiNox
Keep us updated
Zero3hero
One more thing to add. Your phones battery consumption graph will change as the device learns how you use it over time. So if you go months of barely using your device and then start using it very heavily you will notice that the battery graph will adapt to this over time.
In your case WiFi on all the time shouldn't make that much a difference but screen on or device awake definitely will.
Cheers.
