4.3 battery drain
Nathanasiou
4.3 battery drain
Hello, im having andoid 4.3 and my phone battery drains so fast... On battery settings says screen uses 50%!! Whats going?
profile.country.RO.title
_alexdon_
Yes,the media server is using some battery,but the rest is fine.
alexdon
7 REPLIES 7
_alexdon_
The screen drainage is normal,if you would have the Android OS or google services first,you will see an erratic battery life.
alexdon
Nathanasiou
No, other services are like 14%, but first is the screen with 49-50%! 49-50% is normal? Face_with_open_Mouth
_alexdon_
Yes.You should post a picture of your battery graph.
alexdon
_alexdon_
alexdon
Pat71240
Since download of new system (4.3) battery drain.
Is it possible to come back to old system 4.2 ?
_alexdon_
Check XDA forum,there is no official way of downgrading.
alexdon
