Xperia ZX. Call settings Android 8, where are they, I can't hide my number or change network settings
Gone? Without it I'm going to bin this phone
Hi @Paula4u, welcome to our forum!
You can find the call settings if you open up the Phone application and then tap the 3 dots in the top right corner > Settings > Calls.
Here you can find settings to hide your number and so forth!
Let me know if that helps!
Yes thanks just found It, they moved it?
Hi again @Paula4u, glad to hear that you were able to find this setting!
It has been moved in Android 8.0 as you no longer have the "Call/Calls" setting directly under Settings, so you will have to go trough the phone application to be able to access the settings where you can change caller ID and so forth!
Let me know if there is anything else and have a great weekend!
