Xz2 battery drain android pie
FaizZawawi98
These battery drain is just ridiculous for last couple of days... I've tried clean the google's services cache... Done factory reset... The result would be the same... Help me..
5 REPLIES 5
Martin1
Enthusiast
Hi @FaizZawawi98, sorry to hear about this.
From what i can see in the image that you have attached, the phone was at 70 percent charge when you checked the statistics and took the screenshot. At 70%, the phone has not yet been able to do an accurate calculation of your usage. My advise is that you use the phone as usual until the phone is at about 10-20% charge, this will let the statistics give a more accurate representation of which apps or features that is consuming battery.
Please try this and let me know how it goes!
FaizZawawi98
It is because when i leave overnight on standby... I got around 20-30% battery drain...
Martin1
Enthusiast
Thank you @FaizZawawi98 for the quoick reply.
The reason as to why the Android System is using up so much battery may be due to the fact that you recently did a factory reset on the phone. As i mentioned before, try using the phone as usual until the phone is at about 10-20% charge. when the battery is down at 10-20%, take a screenshot of the battery statistics again and post it here. Then we will have more information to go on.
FaizZawawi98
Okay will do... Noted that i just background restricted the android system from the battery..
FaizZawawi98
I think it's better after i restricted background android system... Quite heavy gaming there... Battery down to 15% then i started charge it back
