Hello. screen bleeding issue at top of display ... Is this another Cost cutting feature from SONY ?
https://drive.google.com/file/d/0B9IzoYJfJR2JazNMdkdTUkh5clk/view?usp=drivesdk
https://drive.google.com/file/d/0B9IzoYJfJR2JSXY5Yjd2THpsdGM/view?usp=drivesdk
It looks similar to white line noise issue reported by other users.
Is this white part always visible?
Backlight Bleeding: A LCD Problem
The entire surface of a LCD panel is backlit from behind by a light source (CCFL or LED) and the LCD blocks out the light that is not needed when displaying a particular image. Backlight bleeding most commonly occurs when this light is not 100% blocked, allowing excess light to "bleed" around the edges of the LCD panel. This backlight bleeding issue leaves spots of lighter areas on a dark or black background.
No, not always it's a Quality control problems ...
Or, so it's entirely seperated issue from the noise issue.
Is it visible front on, or just at an angle?
no it's not visible when you look directly at display but at an Angle it's clearly visible ...
I am having the same for a while, I just let it be, however, now the VERY Top part of my touch screen is not responding to my touch. which means notification I am not able to watch due to not able to pull down the notification...
I tried to Remove the Sim card and Clear phone cache, both no luck, now doing the Software repair via Xperia Companion (Mac) hope it works out.
@bthq if you still have the problem after the software repair, check if you're able to pull down the notification pane in landscape mode. if you'll be able to do that while still being unable to pull it down in vertical mode, then it's probably a hardware issue 😕
@najodleglejszy wrote:@bthq if you still have the problem after the software repair, check if you're able to pull down the notification pane in landscape mode. if you'll be able to do that while still being unable to pull it down in vertical mode, then it's probably a hardware issue 😕
Thanks najodleglejszy,
after reseting FOUR times, I am able to pull over few time only. Sometime it automatically came down and go up then down again, however, in landscape mode it is okay. seems mostliky its the hardware issue. only bought for 1 month, come on, I sure i didnot drop it... I am not goona to by song phone any more......
