Two days ago I updated my device to latest version(47.1.A.12.179), and I found that I have to press at least ten times to light up the screen or lock it up.I don't know what's going on there…
Hi i have the same problem. Do you solve this problem?
didn't solved but it works when I press it hard, most of time it works but can't lock the screen when use for a long time
the same problem with you. It usally happened when I put it in my pant, but when it is on a table or sth like that, I can turn on it easily. may be due to software?
