XZ Premium cannot reconnect to WiFi after Oreo
RussianOne1
Hi there!
After update to Oreo my XZ Premium (and my XZ1 Compact) sometimes (but not always) cannot reconnect to saved WiFi networks. Even if I go to WiFi settings and force it to connect via menu it still cannot connect. It connects smoothly after restart. Very annoying.
Another interesting bug is that sometimes it takes my phone quite a while to open address book. Restart cures this one too.
Any idea?
135 REPLIES 135
mlateef91
I have the same issue on sony xzp. Anyone can help fix it please?
Matancur
My xz premium disconnects from wifi very often. Ever since oreo update, I have to be very close to the router to stay connected. If I go into the next room, signal drops low and disconnects many times, something that doesn't happen on my other devices.
Adrastos85
Same for me after oreo update. Phone is next to useless for me as it is....
organman1
Same problem with xz premium shows its connected to WiFi but then shows no Internet connection very annoying I thought it was my home WiFi at first but that's all fine  can someone help sort this otherwise its by by to Sony
profile.country.NL.title
Strampke
Let's go through the troubleshooting again.
There are 2 relevant pages to read.
I cannot connect to my home WiFi network and my WiFiconnection keeps dropping
One more thing to try is goto settings->system->(scroll down)->tap reset->and tap Reset network settings.
Last resort is Xperia Companion with a software repair
Please report back which action helped you resolve your problem.
Jaake
Same problem here. Did elaborate factory reset, nothing changed.
After the reset reconnects WiFi for some time, then loses again, terminally. Having this problem more than one month, data plan overruns...
Tags (3)
Species8472
I'm doing some research, and i found few possible reasons which are related wlan routers. These settings should found almost any modern router.
1. Disable WMM APSD power save option.
2. Set the Network Key Rotation Interval to much longer timeperiod. Usually default is 3600 sec =1 hour. Try 10 or 100 hrs by adding 1 or 2 zeros that 3600 sec.
3. Set SSID always visible. There's no point to hide it. Only foolproof way to secure wlan is strong password. Even SSID is hidden, it can be easily found by appropriate software.
4. Try different Control Channel.
5. Use only 5GHz network if possible, and completely remove 2.4Ghz from the phone.
Saman2
I have the same problem and ineed restart it all the time
Marioss
I have this problem too. I have also dual and also i try everything
Marioss
My wifi crashing after about 5 minits and i must restart it again..  again.... I tryed everything
