Hello, I recently had a problem with my phone. I think it started after it fell on the ground but everything looked fine so I ignored it.
Next day I started noticing the top part of the screen is laggy. Or sometimes it doesn't respond at all. The rest of the screen works just fine.
So I started the safe mode and the problem was still there. My question is if I did a factory reset will it solve the problem? or it have to do with the hardware and there's not point of a factory reset?
Thanks in advance.
Hello again!
@BoMa, I'm happy to hear that the touch screen is working as it should now after the display got replaced!
@Cmj1, I'm sorry to hear about that.
If you haven't tried performing a software repair using Xperia Companion, I would recommend doing so.
Should you experience the same behavior after the software repair has been completed, please get in touch with your Local support team, they will gladly assist you with having the device sent in to an authorized service centre.
Let me know how it went!
Hi @Lynnnuts,
I'm so sorry to hear about that.
Could you elaborate on which behaviour you are experiencing with the touch screen? Is the touch screen not working at certain places or is it something else?
If it's not working on all parts of your touch screen I'd recommend trying the touch test in the service menu of your phone that @dandy63 recommended.
Open up the phone application > type in *#*#7378423#*#* > Service tests > Touch > Free Drawing test.
How is the touch screen working in the test?
Based on your previous troubleshooting, for example reinstalling the software twice it sounds like it's related to hardware rather than software and in that case your phone will have to be sent in to an authorized service, your Local support team will assist you with this and they will gladly help you with any questions you may have regarding warranty and so forth.
Let me know how it goes!
Hey everyone,
just this morning my xz got an issue related to this topic.
It seems like a 2mm band in my xz's screen, doesn't obey my touch commands and scrolls and selects by it's own will, as if an invisible finger is using my phone!
I've scanned my device for any virus and malware softwares, my phone was not damaged physically and I didn't install any kind of new software; I was just using it like any other day when it started to misbehave. I've restarted my phone twice and it didn't do any good.
I really don't know what to do and don't know if it's related to hardware or software...
I'd really appreciate any help, tnx in advance
Hi @SonyUser912,
First of all, make sure that you haven't activated the glove mode feature in your phone, that will make the touch react a bit different from how it normally works. You can find this setting in Settings > Display > Glove mode, if it's turned on trying turning it off and see if you notice any difference.
If this is already deactivated or if there is no change when it's turned off, I would recommend that you try the touch in the inbuilt diagnostics test in the phone, this test can be found in Settings > About phone > Diagnostics > Test > Touch screen.
Do you experience troubles with clearing the screen at the specific place in the test?
@jonas, tnx for the reply
Glove mode wasn't activated, I did a free drawing test by using that Xperia service test number : *#*#7378423#*#* and I've attached the result. BTW, what that actually amazes me is the fact that my phone, connects the touch between the top area and the touch between the bottom of that area.
Let me explain:
1- first of all, those straight lines are drawn continually and I didn't actually touch the screen twice for each of them.
2- the 2nd anomaly is the fact that, the rectangle which specifies the not-working-normally area, is drawn by my finger, when moved across the area, I didn't draw the top and the bottom lines, separately.
It's like the area, functions like a portal or something 😕😂, it behaves, as if my finger is touching both the top and the bottom of the area simultaneously.
It is really bothersome and pr easy weird, I still haven't got the time to go to the Xperia Customer service/support, yet...
I still appreciate any and every help you guys can give, tnx in advance again 🙏
I have a little problem with my Xperia XZ's touchscreen.
The top of the touchscreen doesn't working (nearly the Sony label):
- I couldn't write anything to the google play searching label but if I rotate the phone, I could write to the searching label.
- I couldn't remove icons from the main display (in stand mode) becouse I pull the icons to the deleting zone it out of working BUT if I rotate the phone and display I could remove aps if I pull the icons to the deleting zone.
- with Facebook aps the top of the screen (nearly the Sony label) is working!
So I think there is some softwear problem and I think a new update will could solve this kind of touchscreen problem.
