After updating to latest update 41.3.A.2.58 I began experience problems with playing music over A2DP. I tried useing several devices: JVC Car Play, Nokia BT Stereo Headset and several more. Every time there is one problem - BT switches off for the half of second and then back on, and the music stops. The time after starting music is always different. I've noticed on thing, when I switch off BT by myself, the playing song is set on pause, but when the issue happens, the song is reseted to the begining. I tried to do software restore through xperia companion, but the problem appears again after useing a phone for a few days.
May be some one knows the fix? I do not want to go back to 7.1, or the first release of 8.0 because it is quite laggy.
Thanks an advance.
I am facing similar Problems with my new XZ1 Compact.
It refuses to connect to my car's multiMulti Device (2017 Mercedes C-Class with Comand Online).
It looks like XZ1 Compact is not supporting A2dp Bluetooth Profile.
Software is 47.1.A.12.34.
Is there any fix or workaround?
Not the same.
About your problem, perhaps this is the problem with BT came with the update to Android Oreo.
Btw my propblem has disappeard by itself O_o for now... It's about 5 days everything works fine
