Used Xperia XZ for 5 days and found network issue. Often very weak signal and no Internet service. Incoming calls not possible sometimes. And now, even worse, No Service, could not locate network. Replaced SIM card, issue not solved. Put the same SIM in Z2 and it works very well in the same place. Anybody got any idea? Signal strengths show the same for both Z2 and XZ at -99dbm. The XZ is now unusable and I needed to go back to my Z2.
Tested in safe mode. You can see there is no signal. I also did the software repair. Nothing better. I guess I need to send to service center. Very disappointed for a 5 days old flagship device.
I can't see the screenshot, I wonder if you inserted the SIM card backwards? if not, or even if you did, contact your Local support
I have a same problems: Wifi and mobile network are very poor when my Z1 Compact has very strong connection. The mobile network on my XZ always shows 1 bar only, the Wifi shows 2-3 bars while my Z1 Compact shows that everything have a very strong connections
