Vibration when connected
On most phones there is a vibration when connected, which is very convenient. XZ1 there is no such function and the application structure on it does not work sad
Вибрация при соединении
На большинство телефонов есть вибрация при подключении, что очень удобно. XZ1 нет такой функции и строение приложения на нем не работают
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
The phone does vibrate when you connect it to a wall charger, do elaborate on your issue.
Install tasker - you can create profile which will do whatever you want (including vibrate) when power source changes...
Whether it is possible to turn on vibration when connecting a call is very convenient. Third-party applications do not work.
