Since the September uodate I have a serious issue. Along with the call receiving bugs described on other topics I also have a problem with ghost swipes. Sometimes my phone gets into a "state" that triggers the notification slider even though I'm just typing, swiping or generally touching somewhere else. I can't fix it in any way I can only wait like 30 seconds before it goes back to normal. Any help?
seems like I have the same situation
I've got the same issue. Did you find a solution yet by any chance?
Well, same issue on my end. And I almost thought having dropped it (just a minor scratch) might have caused it.
Happens a lot in games here while tapping certain zones in the screen. But that differs as well.
Let's hope it is a firmware thing that's fixable (Android Pie / 9.0.0 running here) and soon too.
Silly thing is that it seems to be intermittent so pretty hard to reproduce. That said, I read a lot of people having general touch issues (dead zones, needing to swipe 5mm before the device registers anything) so this better *be* fixable by firmware or else what... Recall?
Try changing the display size to something else to see if to solves it?
I have this exact problem, it's extremely annoying, happens sporadically. Sometimes a lock/unlock fixes it for a time, this seems like a software problem. Any news?
I don't have an answer but investigating is always a good start.
- do you have five mode activated (sorry - supposed to be glove - autocorrection)
- does it happen in safe mode too?
- do you have a screen protector
I don't have a screen protector, don't know what five mode is. And to test in safe mode I would have to run it continually, it's not feasible.
Glove mode is off and the phone passes all Xperia Tests.
You might try safe mode for a few hours.
Hi i'm upping this thread because i'm experiencing the same problem since a few weeks
and i'd like to know if a resolution was found
this is a really annoyng problem
