Thouchscren problem sony xzp
Armend
Since last update to oreo and than  pie) the touchscreen is not working like top bottom line in corner doesn't exist, this is very disturbing can't write swipe, any help regarding this issue.
4 REPLIES 4
Martin1
Enthusiast
Hi @Armend and welcome to our community! Slightly_smiling_Face
I am very sorry to hear about this.
Have you checked if the response of the display is the same using the display test in the support application? In order to check this out, please find and tap Settings > Tap Support > Tap Xperia Tests > Tap the test called "Touchscreen".
Another thing that you can try is to reboot your phone in safe mode. All apps downloaded from Play Store is temporarily deactivated in safe mode and by doing this you can see if there is a downloaded app that is causing the area at the top not responding. To find out more about safe mode and how to use it click here.
If none of these measures manages to improve the response of the display i would suggest that you try to perform a software repair using Xperia Companion and a computer. Just make sure that you have made a backup before performing the repair since the repair will erase all user data.
Try these measures and let me know how it goes! Slightly_smiling_Face
Armend
Sony support
HI Martin
Screenshot_20181214-183048.pngThank you for your reply i am very happy about this email but i must inform you that i tried all three options as above mentioned the, touchscreen test, safe mode and repair software  but non of this three solution helped. If i may just send the screen shoot of the touchscreen test so you cold see for yourself the problem, (and worth mentioning that for very short period of time works a bit and than stops again i mean time to time but that's just for a bit) I never had problems with Sony mobile devices until now, i had so many of them since Sony Ericsson time.
Thank you for your time hope to here soon and find the solution.
Best Regards
Armend
Armend
Also forgot to mention when pressing the back screen button also the home screen button is pressed the very same time both of them so sometime goese back and sometimes goes to home this is annoying. It is getting worse
Martin1
Enthusiast
Thank you @Armend  for your quick reply and the screenshot.
Based on the screenshot that you attached, it seems like the left part of the display does not respond.
If the software repair did not manage to improve the touch function I would suggest that you contact your local support team in order to have your phone sent to an authorized service center. If you have any questions regarding the service, such as routines, warranty and consumer laws, these type of questions are best answered by your local support team as well, as they vary between markets.
Have a nice day and let me know if there is anything else i can help you with!
