The emoji does not appear
qwer23
Emoticons do not appear correctly or are compatible with other icons
So it appears in a graphic or sketch, not in the form of a cartoon or a color scheme
عدم ظهور الايموجي
الرموز التعبيرية لا تظهر بشكل صحيح او متوافقه مع بقية الرموز
لذلك تظهر بشكل رسم او مخطط  وليس بشكل كارتون او مجسم ملون
4 REPLIES 4
@qwer23
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I can't see the screenshot, are you experiencing an issue with a preloaded app or a third party messaging app?
qwer23
An emoticon does not appear Emotions do not appear correctly or are compatible with other icons So it appears in a normal drawing without color or black, and not in its original form Please answer. I'm a regular Mobile Android 7.0 clientScreenshot_٢٠١٩٠٦١٤-١٨٥٦١٩.png
@qwer23
I don't quite understand the issue but keep in mind that not all emojis will be compatible with all the apps, which app are you experiencing the issue with?
qwer23
I have the problem in the android system it does not support some emoticons or emoticons either in the applications alvis and intgram and the rest of the applications do not support most of them Which I thought was a problem in the system Do I root it for the system
