With Lineage and Disney Kingdoms.
At the beginning of the game all the sounds are present but after a few seconds only the music remains and all the other sounds disappear.
I reset the smartphone hoping to fix the problem because I had 2 system updates on the first boot. so I have the latest June 1st security patch.
I specify that the volume is set correctly, I am not in silent mode or do not disturb.
I turned the sound vibrations on/off and told myself that it could play on the audio stream.
Tries also to reboot the device...
This is extremely disconcerting.
Does anyone have the same problem?
I also have the same problem but not with the same games, as above but several others... Gets quite annoying .
