Sony zx premium where are sim contacts
Roxy786
Hi i cant set my zx premium to store new contacts to sim only how do i do this
2 REPLIES 2
profile.country.PT.title
NunoSEN2
Hero
@Roxy786;
You can't set to store new contacts on SIM card but you can transfer all contacts to your SIM card, go to contacts >top left 3 lines menu >settings >export >select SIM card.
Jonas
Hi @Roxy786, welcome to our forum!
As @NunoSEN2 mentioned, you can't save them directly to your SIM card, but you can export them to it.
Keep in mind that the SIM card can't store an infinite amount of contacts, so saving them to your Google account is almost always the best option as they will be shown after adding your Google account again for example, performing a reset. You can also edit, remove and add contacts using the Google Contacts website found on the link below.
contacts.google.com
If you only have them locally stored on your device at the moment, you can export them to a .vcf file that you then import and choose to store the contacts on your Google account. Follow the instructions below.
1. Open up the Contacts application and tap the three lines in the top left corner > Export > to SD card or internal storage > tap save.
2. When the export is complete, tap on "Import" > choose the file that you created when exporting > choose your Google account > Import.
I hope that helps! Slightly_smiling_Face
