Sometime can't connect with wifi until restart
minhtrism
Sometime i can't connect with my wifi or drop connection when i retry to connect, it said "disabled" or "saved". Persisting since last android 9 update 47.2.A.8.24-R3C - Customized VN. Only work again till i restart the phone
mahesh911
@minhtrism wrote:
I don't know, it works fine before update. I noticed this usually happen before i go to sleep, around 10:00 PM to 12:00 PM. Maybe it relate to Xperia Action
Then also force closing Xperia assist too. And btw today released the new update with march security patch. Don't know other change logs.. update it and see if there is any improvements.Screenshot_20190326-124454.png
3 REPLIES 3
mahesh911
Hii... The mentioned WiFi issue happened for me too.. do u have Netflix installed? Iam not saying it is the problem but it appears after Netflix these network issues came.. something it might be affecting stability of the network.
Ok the solution is like u said restart.. and if the problem continues to occur, just reset the modem..or router.. a couple of modem reset ensures the WiFi network to stay...
minhtrism
mahesh911
