Request: could Sony work on customized setting to disable vibrate globally?
mynameisnaveen
could Sony work on customized setting to disable vibrate globally? I always loved Sony for the customization it brought to the OS which is not good enough with other vendors. Hope Sony could revive that culture
2 REPLIES 2
stanlykubrick
Not exactly sure what you mean by "vibrate globally" but I am able to turn off all vibrations if I want to.
profile.country.PL.title
najodleglejszy
@StanleyKubrick even if you disable vibrations during incoming call ringtone, other apps' notifications can still use vibration unless you disable it in each app's settings or switch to DND mode. I think @Naveen3 wants a mode where you get notification sounds but no vibrations at all.
