Reboot when connected to car USB
Grouch
Brand new ZX2 compact with software fully updated. As soon as I connect it to a USB cable in my car, the phone reboots. Any reason why?
15 REPLIES 15
Grouch
It doesn't charge the phone and sometimes causes it to lock, vibrate for about 5 seconds and then reboot. It won't function whilst connected to the USB cable
JiYong
New
Can you try to use the cable that comes with the charger?
Grouch
I've used the Sony supplied cable and a third party cable. Same problem.
MechaBouncer
I'm having a similar situation with mine. It happens every now and again, but it is most frequently when I plug the Sony USB A-to-C cable into the phone when connecting my car to Android Auto. The screen goes black, the notification light blinks red, and the phone reboots. This morning it did it 3 times in a row before I shut the phone off then powered it back on and then it worked. Sometimes I'll go days or weeks before it happens again. I'm not sure what to look for or if there's any sort of logging that I can submit. It's possible it may have started near when I switched from using the cable that came with my Xperia X Compact to the one that came with my Xperia XZ2 Compact, but I don't really recall. I do know that the charger that came with the XZ2C was dead and never worked. I'll try a different cable and see if that makes a difference. The Sony cables seem like junk and after awhile stop working if you don't plug them in a certain direction even though they are USB-C and it shouldn't matter.
profile.country.NL.title
Strampke
Hi @MechaBouncer
Same happens to me when I plug an USB cable into my computer.
Is it static electricity, is it a + to earth shortcut?
I don't know.
Anyway compter screen black, computer unresponsive, need restart and everything is OK.
In your case think of something similar.
MechaBouncer
It's gotten worse since then. At this point Android Auto no longer launches on the car. I can still connect to a computer and read the contents of the phone and memory card. I'm in contact with both Google and Sony Support regarding it. I've submitted bug reports to Google including all my troubleshooting up to now and Sony recommends a software repair through Xperia Companion. I will most likely try the software repair next, but I'm highly suspecting that something has blown in or near the USB port. The bottom speaker has sounded all tinny for several weeks and I keep losing GPS signal while the USB cable is connected.
Strampke
As far as your reports go I would choose the USB port as cause of all troubles.
Nice that you included Google support in your search for a solution.
As far as my knowledge goes on this forum I must say that it's always good to try to find the cause of all evil, however skipping that step and go for a software repair gives the best result in most cases.
You will never find the real cause but the satisfaction of owning a device that does what it should do wins.
Anyway, be it the USB port or the software, I sincerely hope that things will go as it should on short term.
Keep us informed.
MechaBouncer
Well that was a waste of time. Did the software repair. Reset EVERYTHING in the phone. Waited for it to finish reinstalling all of my apps. Connected to the car and nothing. I can still connect to a computer fine, but it just doesn't respond in the car. And other phones work just fine in the car with the same cables. Something is broken in the phone that wiping the software cannot fix.
Strampke
A software repair cleans up everything.
When you restore your apps it is possible that you restore trouble as well.
Some 3rd party apps have the bad habit of mixing things up.
The one and only test is a software repair followed by only installing the most urgently needed apps. Leave SD card out, these also my have a tendency to cause trouble when they are at the end of their life time.
Then test in your car.
If it works problem is resolved and restore whatever you want.
If it still doesn't work then send your device in for repair.
How does your phone connect to other cars?
