Problems after update to 8.0
Sgamo
Hi
After the update I have a lot of problems : the GPS icona never turn off,  70% apps included original installed always stop working, nothing change after restart either the app or the phone.
stanlykubrick
You need to run the phone in SAFE MODE and see if your issues are resolved. If they are then you have a third party app that is causing the problem(s) and will need to be deleted. You will have to delete them one-by-one until you determine which app is causing the issue.
If running in safe mode doesn't fix your issues then you will need to do a software repair using Xperia Companion. This will reset the phone back to factory settings but with all new software. So you will have to set everything up from scratch.
