Phone volume too low
Salve ho xz premium, all'improvviso si abbassa il volume del telefono  , se faccio riavvia  poi funziona bene  , dopo un paio d'ore, stesso problema . Ho provato reset di fabbrica, pc companion riparazione software, ma mi ridà lo stesso problema.
Hi I have xz premium, suddenly the phone volume is lowered, if I restart then it works well, after a couple of hours, same problem. I tried factory reset, pc repairing software, but it will give me the same problem.
GT
7 REPLIES 7
ChloeS
Hi @Pantera67
I have translated your post as this is a Global forum all posts/replies must be in English Slightly_smiling_Face
When you completed the software repair, did you reload all of your data and apps straight after the reset or did you test the volume issue before doing this?
Let me know Grinning_Face_with_smiling_Eyes
Ho provato subito efunzionava bene, ho impostato tutte le appapplicazi, ha funzionato una settimana e poi stesso problema
I tried immediately and it worked well, I set all the applications, it worked a week and then the same problem
GT
profile.country.PT.title
NunoSEN2
Hero
@Pantera67;
I think it must be an app that is doing that, do you have some Xperia Actions function enabled?
ChloeS
Hi @Pantera67
Again I have translated your post, please remember all posts/replies must be in English as this is a Global forum Slightly_smiling_Face
Since it functions correctly immediately after a reset then slowly returns, can you test the phone in safe mode and see if you still experience these issues?
ok dankyou
ChloeS
No problem @Pantera67
Were you able to try that? How did it go?
Let me know Slightly_smiling_Face
Englishmanx
same problem here. The volume acts normally and after some time it lowers all of a sudden. After restarting the phone its normal again for a few hours when it lowers again. Safe mode has the same behaviour.
Not to mention GPS bug which is also present. As said before, the person responsible for the last update must be fired, until then my phone was PERFECT. I wish was able to revert to my previous version which was excellent....
