I cannot find the option to auto kill WiFi during standby anymore in Pie. Is it removed? Are there alternatives? Auto kill saved me a ton of battery...
Also no more option for WPS connection?
Well seeing a 5-8 times higher standby battery drain, it doesn't seem like an improvement, does it?
Hi @Mehmeh, please see the PM that I sent you a while ago regarding the battery running out faster!
What was the PM?
I miss wifi kill a whole lot
What information do you have about the battery running out faster?
I'm experiencing the same without wifi kill.
Hi @Yupp, I asked for some further information.
Wi-Fi still being active in standby should not really have a big impact on the battery life as it will only check if there is still a connection from time to time, and if the connection is good, this will not impact the battery life that much.
If you experience battery drain while the device is in idle, try and restart the device in safe mode and keep it in this mode for example when you are sleeping so we can see if any downloaded application is causing this as they are temporarily disabled while the device is rebooted in safe mode.
Keep me posted!
