NFC problem after Oreo update
dreams970
NFC not working after Android Oreo update. Could Sony quickly resolve the problem? Till now there is no update or remedy. There are quite numbers of issues after the android update. Please test the update first before rolling out for updates. Very disappointed 😥
21 REPLIES 21
profile.country.NL.title
Strampke
Just a wild guess:
What if you goto settings->apps & notifications->app info-> tap the 3 dots in the upper right corner->show system-> scroll down to NFC service-> storage
Then clear data and clear cache
What happens then? Is it repaired?
I am afraid not because some report a factory reset is not successfull or safe mode doesn't resolve the problem.
Anyway, it is worth the try isn't it?
Report back if this is usefull for you please.
Gk92
Clearing cache and data not resolved the problem. Also tried in safe mode, nfc not working
Tags (1)
Mehrd
I have Xperia XA1 plus and android 8.0.0
And NFC does not work
Necroteck1
Hello,
My NFC is not working i have a 8.00 version of android (Oreo). Any answers? I had reset to factory, reboot, clear cache, try in safe mode. But the problem persist.
GregCandra
Me too
jamaj666
I have the same issue. I carried out factory reset just yesterday. Problem remains.
Jabberjayjay
Xperia xz android 8
NFC handshake stops after a second and says read error.  This has been happening since last updates mid 2018.
AliAbdullah
gents,
I have the same issue regarding NFC not working on Xperia XZ
the suggested options already done without any seccuss
(Factor reset, Safe mode, Repaing by Compion)
until I've noticed when pairing, I need to press devices a little pit more to NFC Area to  activate it & it's worked !!
looks like the NFC Area getting affected by somehow !!
from the update itself
or from (the phone getting old & its usage - which shouldn't be a reason)
please try this way & share the experience you have
Sony's delevepor team,
please try this method in old Xperia XZ phones and abserve if the reason
is the new update, weaking the NFC Zone signal & coverage
Best Regards,
Ali Abdullah
nourfit
Thank you very much. Alhamdulillah it works!!!
I was desperate searching solution till i read ur suggestion to press device bit more...
AliAbdullah
Happy to know the suggestion works with others
Please note, the NFC pairing getting better by the time
