Force restart and factory reset diddnot help i also tried change cable and adapter too..
Ampere app
Settings/Battery
@M3nYuSyou could try performing a software repair using Xperia Companion (which is different than performing a factory reset). if that doesn't help, then it's most likely a hardware issue and you should contact your Local support to schedule a repair.
