Loudspeaker not very loud on phone calls yet ok when playing music
Hotshothammy
2 REPLIES 2
Damo_
The music volume (Media volume) and in-call loudspeaker (In-Call volume) have different volume settings (sliders) in the phone menu.
In the first instance I'd advise making a call, putting the phone on speaker, and then toggling up the volume key to make sure In-Call volume shows as maximum. This is also independant of In-Call volume when listening through the standard earpiece during calls so just because your In-Call volume on the earpiece is max doesn't mean it is on the loudspeaker.
profile.country.NL.title
Strampke
When you adjust volume you will see a downward arrow on the side of the volume bar.
Tap it and you will see 3 separate volume settings.
