Как настроить телефон, чтобы увеличить частоту мигания светодиодного индикатора при не отвеченных вызовах и не прочитанных сообщениях?
How to set up the phone to increase the frequency of the LED blinking for unanswered calls and not read messages?
GT
Hi @VladisLAV179,
This is a international community and I have translated your previous post in to English so that other users may more easily understand you. Please keep all future posts in English.
I'm afraid there is not such setting, but I will be happy to forward it internally that your request such a setting.
Let me know if there is anything else you are wondering about!
Перевод не совсем точный.
Нужно настроить, чтобы Часто моргала светодиодная лампочка.
А то приходится долго смотреть на индикатор, чтобы понять, имеется ли сообщение или звонок.
The translation is not entirely accurate.
It is necessary to adjust, so that the LED light blinks frequently.
And then you have to look at the indicator for a long time to see if there is a message or a call.
As I wrote in my previous post, I'm afraid there is no setting to change the frequency in witch the LED notification blinks.
Also if possible to avoid translating error, please keep your posts in English.
