Is there a very small gap between back glass and frame ?
SPeaky
Hi guys I will try to explain my question with my english which is not too good lol.While I looking at myself with rear glass(luminous chrome) I noticed something.Left edge of the glass(which is under the camera,behind the power button) there is a really small gap between frame and glass.I can see the stucked dusts in it.If I pressure on it I can even close the gap.(Dont think it like a bit gap because of my words,it is really really small but there it is) But the right edge seems normal,glass and frame seems unified there is no gap,not even a little space. Is that same for everyone? I wanted to ask because in the past I had Xperia Z and it had a chronic glass lift off problem as you know.
And also I have to say that seems like this gap is not a problem for water resistant feature because I used the phone couple times under water and nothing bad happened.Will this situation cause a problem in the future?
5 REPLIES 5
profile.country.NL.title
Strampke
One cannot predict the future.
Have a look at pictures of other devices on the Sony website and elsewhere.
And if you are very worried about it then take a picture of it and contact Sony support.
SPeaky
Could you check for me if it's same for you or not please? I really wonder it is the same for the all Xperia's or mine is not glued well (only for left rear edge because right seems normal)
Strampke
You are the only one that can check because you have the problem.
Try to compare.
Make photos and ask again.
Razor891
Yes I have also noticed a gap on my right corner of front glass and frame. I show it on first day. I really look creepy as these spaces is something filled with dust for which I use notes for cleaning these gap. I really doubt that it will compromise the water resistant ability of the phone. IMG-20171220-WA0000.jpg
SPeaky
Yeah that's why I started a topic about this
