Translation via Google Translate:
Good!!! I want to put ICE on the lock screen so that it appears when the phone is blocked because I have it with a pin and if something ever happens, nobody will be able to use it but I have no idea, my phone is the Xperia XZ
Thank you
Buenas!!! Quiero poner ICE en la pantalla de bloqueo para que me aparezca cuando el teléfono esté bloqueado porque le tengo con un pin y si alguna vez pasa algo nadie va a poder usarlo pero no tengo ni idea, mi móvil es el Xperia XZ
Gracias
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Go to Settings -> Users & accounts -> Emergency information
