The first problem that I had upgraded my Xperia xz to 7.1.1 and still ask about update ..
The second I can't enable android webview .. thank
Hi @Alias596, welcome to our forum!
The phone will only do one update at the time, so if you have a notification in your phone telling you that you have an update available, go to Settings > About phone > Version and write down this number. Install the update > restart your phone and go back to Settings > About phone and see if the number have changed. If it has, you have installed a new update.
Starting with Chrome version 51 on Android 7.0 (Nougat) and above, the Chrome APK on your Xperia device is used to provide and render Android System WebViews. This approach improves memory usage on the device itself and also reduces the bandwidth required to keep WebView up to date (as the standalone WebView APK will no longer be updated as long as Chrome remains enabled).
You can select your WebView provider by enabling Developer Options and selecting WebView implementation. You can use any compatible Chrome version (Dev, Beta or Stable) that is installed on your device or the standalone Webview APK to act as the WebView implementation.
For more information, go to: https://developer.android.com/about/versions/nougat/android-7.0.html#webview
I hope that helps!
