How to disable low battery sound notification
Cerru
As stated, when the phone reachs low battery (30%), it sounds off loudy.
Anyway to disable it?
101 REPLIES 101
profile.country.RO.title
_alexdon_
@Cerru Go into settings - battery, select stamina mode, tap on the cogwheel and change the battery percentage it kicks in.
alexdon
xznewbie
@Cerro,your XZ low battery juice sounds at 30 %? Is it normal? Mind sounds s at 15%and pleased with such warning as it prepares me how much longer do I isebefore I recharge it.
BTW.. Does any body knows if it's perfecty acceptable to have around 2-5% battery juice left before recharging?. My usage habit enables me to get 14 hours of continuous use before I plug it to the AC out let.
Cerru
All that does is giving me the option to choose at which percentage does the notification kicks in.
It does not disable the battery sound notification though.
_alexdon_
Strange, low battery notification should be at 15% only if I remember correctly.
EDIT: Will try to get more info on this, now I am confused if the percentage is 15% or 30%.
alexdon
Sunking1011
It's at 15% and again at 5%.
Xzs
Mine is set at 15%, but it still sounds at 30 and asks if i want to view battery usage.. Wouldnt it be better (save more power) if the phone is quiet so that i dont pick it up and wakes it to check what the sound was about?
_alexdon_
It seems that the battery warning should come up at 30% and it can't be disabled.
alexdon
Sunking1011
Mine comes on at 15% and then once more at 5%, never at 30%.
Emir1
Hero
Hey @Cerru, what you're experiencing is not related to STAMINA but is a system notification. To my knowledge, the only way to make it not emit a sound is by setting you device to either silent or vibration mode.
Regarding at which battery levels the warning comes I'm afraid that I do not have any specifications, other than personal experience at 30% as well as 15%, but I will request that information internally and I'll write here once I know more! Slightly_smiling_Face
