I have an Xperia XA2 (with 3.5mm port and USB-C) and an Xperia XZ2 ( no 3.5mm port and USB-C)
The XZ2 came with an USB-C to 3.5 mm jack adapter, however i cant seem to find setting to connect phone and my ( Beats Solo 3) headphones with it.
Thanks for any help.
Connection problem solved after a restart of phone, i tried different headsets and everything works fine.
Hi @profiler270, sorry for the late response here.
Just an FYI for the future, there is no setting on your XZ2 that needs to be activated in order for the 3,5mm adapter to work. But I am glad to hear that you managed to sort it out by yourself in the end!
Let me know if you have any further questions!
