hello..
i have problem on my xzp and this is the 3rd time happen to me !!
the phone keep restarting i dunno where the problem
i flash latest firmware and phone works fine for 10 days then it's back and do restarting then i have to flash firmware again
please help me from 25-1 to 24-2 i flashed firmware for 3 Time and i lost all my files and i made video shows the problem because my bad english
https://www.youtube.com/watch?v=9XpxsMbc8q8
@Questerwrote:This might indicate that one of your installed apps is causing this.
My apps is [facebook-messenger-whatsapp-chrome-es file explorer-mobikora-opera-pages manager] this is all my apps im using and all apps r updates
If the phone stays ok for 5-10 days after software repair, then something begins to happen after this period. I don't think it is a hardware issue because it would go into restarting regardless of the software. Try to restart in safe mode and observe how would it work there, if no restarts are happening then it's definitely one of your apps.
@Questerwrote:If the phone stays ok for 5-10 days after software repair, then something begins to happen after this period. I don't think it is a hardware issue because it would go into restarting regardless of the software. Try to restart in safe mode and observe how would it work there, if no restarts are happening then it's definitely one of your apps.
Same in safemode m8 its also restart i try every thing
how it happens. because after repair using companion can use. but if i restart or switch off the phone automatically restating when its switch on. i have lost my lots of data because of that. please is there any solution for that. because if my phone restart or switch off i have to repair again to use it. if it is because of app how can we find it because play store shows no any problem with apps. what should we do.
Please give us proper solution
I feel your pain, I'm having the same issue. Look at just last night's restart log.
@Curr946@kanchukaif a software repair using Xperia Companion doesn't fix that issue for you, you should contact your Local support to arrange a repair so that they can take a look at the device.
your one is better. i my hone restart once it continiously restart. i cant use it. stuck and restarting. there may be a issue with software.
@kanchukawrote:your one is better. i my hone restart once it continiously restart. i cant use it. stuck and restarting. there may be a issue with software.
we need to contact sony support to look at this software problem !!
