Dual Sim with SD card not working
19667
i bought nano SIM adapter and i put SIM to that and memory card for the phone. unfortunately my XZP recognize only the SD card and SIM one only. i think there is a limitation from Sony software. is there any way to use both SIM and SD card simultaneously.
Please help
3 REPLIES 3
profile.country.PL.title
najodleglejszy
@kanchuka if I remember correctly, when the phone detects that an SD card is inserted, it disables the SIM 2 slot, and as far as I know there's no way to work around it.
19667
yes i know that thats why i ask is there any way to fixed that. because i need to used both sim and sd card.
najodleglejszy
yes, and that's why I said that there most likely is no way to change that.
according to the manual (https://support.sonymobile.com/global-en/xperiaxzpremiumdualsim/userguide/assembly-ss-content/😞
Using two SIM cards and a memory card at the same time is not possible. The memory card tray allows you to use either a second SIM card or an additional memory card. Do not cut your SIM card, as this may damage your device.
