When I want to open a document, I only have options to use sketch or new suite, how do I change it?
Cuando quiero abrir un documento solo me opciones para utilizar sketch o new suite, como lo cambio?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
you could use a different Doc app such as Google Docs > open the app > then open the file, that should give you an option to set it as default
