I'm using Sony MDR-ZX110 headphones with my Xperia XZ1. After some time phone started to have some issues when headphones were connected. I sent it to dealer for warranty repair and they declined since the issue is not present when oem headphones that were in the package are connected. They said my headphones were probably not compatible.
Headphones are 100% fine, tested also with brand new ones in shop.
I made a video of the error: https://youtu.be/oE4C8DYM-Cs
Please help me
https://www.sony.co.uk/electronics/headband-headphones/mdr-zx110-zx110a-zx110ap/specifications
there are two versions of those headphones
Hi, I'm using standard MDR-ZX110, without mic, with 3.5mm stereo 3-pin connector (mic version has 4-pin 3.5mm connector). This is the ancient 3.5mm standard stereo plug that I used in walkmans, and was there long before smartphones.
The problem is that this same earphones worked for 8months. But my dealer is now saying that they are "not officially supported" on my phone and the phone is fine.
They wouldn't even test my phone with any 3-pin stereo headsets at all, because apparently there is no officially supported headphones that should work 100%. Basically the only wired headphones that are officially supported are those that came with the phone.
