Well Done Sony
The last system update has completely ruined my XZ Premium
Why i hear you ask?
Well since the last system update the phone wont charge with the usb C cable with the phone switched on....Yes get that i can only charge the phone after doing the 2 minute power and volume up button press, every single time which means i have a brick for about 50% of the time.
That is unacceptable and you havent resolved this from the last time you screwed the charging up its just getting worse.
I have had the phone checked by an authorised service centre there is nothing up with the hardware side, the charge port is funtioning properly, the battery is charging, its a complete software issue and you need to fix it.
However congratulations for costing me £50 to check out the parts i already knew were working.
