hi guys
my phone charges but it would drag on percentage rate but it just loses power while its on it will charge like 15 hours if i dont charge it. about 5 days ago it was charging normal then all of a sudden just started charging extremly slow and loses power while its charging if im busy or its just idle.it only charges when it is off....is there anything i should no i dont even have the phone for 11 months yet
Hi thank you for your response.
I have not added any app with in the last 7 days last night how ever I did do a factory reset from the phone a and still the same result
@quester
Changed the cable on Monday used 2 plugs as well as a car charger. I am thinking of using Sony companion to restart the phone.
I don't think the battery can be finished with in 11 months
As soon as I get a result I will get back to you and let you what the out come is and that will happen tonight.
Thank you for your help this far
So I did the software repair and didn't help. Amy other suggestions that does not require me to send my phone half way across the world
used a third different charging cable and it worked and charging as per normal
