Camera can cause system RAM usage rise
VantaBlack
Customized VN  47.2.A.10.62
Just turn on camera for a while can cause this issue, and system RAM usage become higher after 4K recording.Normal stateNormal state
Turn on camera for a whileTurn on camera for a while
after 4K recordingafter 4K recording
7 REPLIES 7
mahesh911
Are u sure abt this? I'm about to update to 47.2.A.10.62
Restart phone after the update?
VantaBlack
last version also have this problem
mahesh911
I didn't see particularly any ram usage rise in 47.2.A.10.45 normally has around 1.5gb ram free.. now iam updating to 10.62.
mahesh911
Ya I see it... I think it should be normal. . and after system ram rise it stays in memory so as to resume fast camera switching operations I guess.
Does it stays like that all day long if u don't use camera app afterwards?? I will check too just asking... Think it will adjust itself away after sometime according to ram management.
VantaBlack
yes it will be reduced, and it looks better than last version.
last version can reduce to 1.7 or 1.6GB, and now is 1.4😉
mahesh911
It doesn't matter.. it's system app.. system manages it no problem..  I tested it.. system usage went 1.5gb to 1.9gb after 4k recording  and snaps.. and after 15min after using other apps and checked again it's back 1.5 or 1.6 varying.. which means it's temporary not an issue or bug.. when it runs it indeed stayed in memory and it will not affect other usage.  It works according to ram management setting. Nothing to worry about..  it's fine..
Thanks Sony for next may up-to-date security patch ... Keep it up..
mahesh911
It's completely normal .. camera app does need that much memory to run.. I tested it.. system usage was at 1.5gb and it reached 1.9gb after camera snaps and 4k recording. Then some 10 minutes later using other apps and checked to see it's back 1.5 or 1.6gb which means it runs temporary so as to u can start camera app faster.. it's not an issue. It works according to ram management setting... So no problem.. it doesn't affect any usage . It's fine
Thanks Sony for the may up-to-date security patch..keep it up.. keep it going..
