The sounds control is broken on Xperia XZ Premium broken. When you push volume button the volume control panel shows up with media slider. Thats ok. But if you tap on settings gear under slider it should show all volume sliders next to media volume slider but instead of it it brings you to phone volume settings.
Hi again
What we must do with text message app ?
As someone mentioned, the ringtone volume is previewed when you adjust the volume in settings.
At best, it is useful the first time, but not the 1000 following times when you already know what visual level you want, and need to quickly silently adjust the ringtone volume.
Sad to say that I am looking for an app/widget to rebind the volume keys to how it was before the update
Hi @MehrdadVz!
I'm not quite sure that I understand what you mean with the message application, would it be possible for you to elaborate a bit? Thank you.
Hi @FatCash, That is very true and I understand that must be very annoying, especially if you are adjusting the volume to not disturb the people around you.
I will make sure to forward the feedback regarding this!
In my last version of Android I used messaging app .with this app I can stared🌟 message or messages and in inbox of somebody I can selected too many incoming messages to delete or... But not this app crashed in Android 9 and didn't work . Recently I must use messages app , this app is very simple app I seen in very old version of Android .
Hi, yesterday I received Pie update and since then the volume rocker is changing the volume of multimedias instead of incoming calls and messages!!!
I need to open additional menu in order to adjust call volume. How can I fix it?????
Please help!
Can this setting be adjusted???
It is so stupid!
Exactly! We need to be able to adjust "default" value of volume rocker, I for example want it back to adjust i coming calls / notifications vokume with the rocker directly and not sub menu! Also playing the sound automarically in sub_menu is annoying.
This bug must be fixed immediately!
Yes, When the control volume appears you need to tighten the configuration gear, and it will send you to the options of other volumes. the only shortcut is to put on vibrator and not bother at the top.
Yes, very stupid as it was perfect before, I can not figure out how to change that
@MehrdadVz, Do I understand that you are using a third party messaging application and that one is no longer working after updating to Android Pie? If that is the case, check if there are any updates to the application available in the Google Play store, as the version you have installed may not be fully compatible with Android Pie.
If there are no updates available, you can find the contact information to the developer of the application in the Google Play store and send them the information, so they are aware of this.
@azzido, There is no setting to change the behaviour of the volume slider and to adjust the ring/notification volume, you will need to tap the cogwheel and manually adjust it in the audio settings. This is the default behavior in Android 9.0, so there is no bug.
@Dcorrea, that is correct. With the "bell" icon, you can either mute all notification/ring sound, only vibration and of course, sound on.
@ReneMeyer, You can not change it back to how it was in Android Oreo, as this is the new behaviour in Android 9.0 (Pie).
I do understand that this change does not suit everyone and I'll continue to forward all the feedback that I receive about this!
@Jonas wrote:@MehrdadVz, Do I understand that you are using a third party messaging application and that one is no longer working after updating to Android Pie? If that is the case, check if there are any updates to the application available in the Google Play store, as the version you have installed may not be fully compatible with Android Pie.
Hi, what was the answer after the feedback?
Will this issue introduced by stupid Google be fixed/corrected by Sony???
This is so annoying...
