Just found this article.
https://sumahoinfo.com/xperia-xz1-compact-so-02k-docomo-fuguai-issue-body-twisted-distorted
It's in Japanese but what it's reporting is basically that XZ1C body is slightly twisted, and as result, the upper side "lid" doesn't fit the body.
Anyone noticed the same issue?
If the device it's available in your country, you should go check it out at the store.
I'm hesitant to believe it as the title of the article starts with the so called "Distortion" issue, which it's not quite an issue but how wide lens work but that's another topic.
I just inspected mine and there's no such thing as a body twist or anything.
Seen from the display, the upper and lower edges are slightly raised to prevent the screen from laying on the surface, but that's intended.
