Bluetooth problem with the earphone started to giggle
0851182238
Начал гикать блютус (Bluetooth), гикает наушник и колонка при поступлении сообщение в смартфон проигрывание музыки, в два раза так гикает и ещё при перелистывание страниц в ВКонтакте, если попадется какие то видеофрагменты, опять гикает
I started to blast bluetooth (Bluetooth), the earphone and the speaker are screaming when a message is received in the smartphone playing music, it is twice as giggling, and even when turning pages on VKontakte, if there are any video clips, it is again screaming
-GT
profile.country.NL.title
Strampke
Don't understand exactly what is going wrong.
In general when there are Bluetooth problems you can start with resetting network settings.
Try that for a start and don't hesitate to come back with more explanation about your problem.
