Bluetooth connection Xperia XZ Premium
Devin27
I have problem with connection my bluetooth. I play PES Mobile, when I try play locally with my friend use bluetooth connection it's always fail. My device cann't connect to my friend's device, vice versa.
Please help me to solve this issue.
#sony xperia xz premium
6 REPLIES 6
mahesh911
I haven't played it but guess u need to pair that device first from Bluetooth and then try pes mobile.
Devin27
But I use xperia test for my bluetooth and I also try to send/receive file via bluetooth are working fine.
Then I try to connect speaker via bluetooth are working too.
mahesh911
Ya I mean manually pair the device in Bluetooth...it shows available devices list which shows the other device name ready to pair. Then after u pair there is setting which shows some permissions with that device.. And then try Pes . I don't have Pes to test.. let's see
Devin27
I already try last night, but still same problem.
I manually pair device bluetooth, pair success but cann't connect. If I try to connect manually bluetooth to paired device, then always diconnect automatically. Just connected few seconds.
mahesh911
Ok I tried installed Pes mobile.. I tested with my Z2. Already paired and even set permission for contact sharing in Bluetooth settings. Then installed Pes in z2 and then play locally option..  in xz premium I created match room and in z2 searched and connected match room and after few seconds clicked confirm and started loading. And I played multiplayer for like 5 to 7 minutes..
It worked no problem.. did u try create match room and then connect?
Like IT guys say try a couple of restarts as well.
And when u connect with Bluetooth make sure u turn off any other Bluetooth devices and let both mobile devices connect peacefully.
Devin27
But I just have one smartphone Slightly_frowning_Face
I will try when I meet my friends, thank you very much for your help and solution.. Slightly_smiling_Face
