I have a problem with the battery in my Xperia xz1 phone. The preliminary estimate shows very high and false values. Secondly, although my device is 2 days, the charge is going very fast. Is this normal or will it improve later?
Xperia xz1 telefonumda batarya ile ilgili bir problemim var öncel tahmini çok uçuk ve yanlıs değerler gösteriyor ikinci olarak cihazım 2 gün olmasına rağmen sarjı çok hızlı bitiyor bu normal mi ilerleyen zamanlarda düzelir mi?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
It'll be wise to repair your phone with XC
İs my battery okay or there is a problem?
hi @MrAlbino
unfortunately I can't understand the language of your device, are you checking if your Xperia XZ1 is behaving normally battery wise? the graph on the device is just a rough estimate, it may change time to time, and may not be update immediiately according to the present charge and usage
for a comparison: I MODERATELY use my Xperia XZ1 , games, youtube, some SMS, a few voice calls, connected to wifi at all times. I manage to get home with 30% battery left. (8am-8pm) with SCreen on TIme arrounf 3hours and 45 minutes.
Türk Türk'ü çekermis, bosver dostum bu lavuklar anlamasın :). Idle tüketimi malesef fazla ancak normal tüketimle bekleme sürenin toplamı günü çıkarmıyorsa sorun var demektir. "Akıllı temizleyici"yi kapatıp öyle kullanmayı deneyin, sahsen ben öyle düzelttim.
I do not know these chickens
Idle consumption is unfortunately too much, but with normal consumption, waiting is the sum of the sum of the day, if there is a problem. Close the "smart cleanser" and try to use it, so I corrected it myself.
GT
