Battery Drain Xz2
AzeeZ3
Battery Drain Xz2
I have an unexpected battery drain.
This my 2nd day I am using a phone and when my phone is idle it eats like 40% in 2hrs. And onscreen use time is 17minutes. ..please help 😣
RuneJ
What is this RCS app on top of the list??
A quick search came up with a similar problem related to RCS on Android Oreo on a different brand of phone:
https://forums.oneplus.com/threads/rcs-draining-battery.657535/
Perhaps try to disable/un-install the RCS app?
20 REPLIES 20
profile.country.US.title
Qatrium
@AzeeZ3
1. I see that "Phone Idle" process has consumed 3% only in 2 hours, not 40%.
2. Give the phone a few days to get its battery consumption stabilize before you make conclusions.
AzeeZ3
Please cheked full details. Better is reached 62% and screen use time is 17m and phone idle process has consume 3% battery.. Is it not look like battery issue
Qatrium
@AzeeZ3
I think the last recharging cycle was not a full one.
To produce more accurate stats: charge your phone to 100%, use it normally until it reaches 15-10%, take a screenshot of the consumption graph and the highest consuming apps/processes then post all the data here.
AzeeZ3
Please find the details.
Battery drained from 100% to 10% within 4. 30hrs and screen usage time is 50 minutes. It's an issue with my phone. Better graphBetter graph
Process consuming the powerProcess consuming the power
Screen usage since full chargeScreen usage since full charge
Qatrium
@AzeeZ3
I think a badly coded 3rd party app can cause this. Again recharge your phone to 100%, but restart it into safe mode once full and test the battery drain. This will disable all installed 3rd party apps, so if the problem is resolved then one of your installed apps is causing this issue and you have to figure out which one. Start by uninstalling those apps you installed recently.
RuneJ
AzeeZ3
There is no option of disable /un-install for RCS app. I thing it is pre-installed app
AzeeZ3
I paid lot of bugs and waited for more than 4month for this phone.. I am using Same apps on my z3+ and other brand and there is no issue.i m not agree with the solution provided(I am customer not tester)  being fan of Sony this is not good.. Show some other options
Qatrium
@AzeeZ3
This is not testing, it's an attempt to narrow up the reasons. Your other option is to perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
There's also a choice to contact your Local support and get your phone examined by a professional.
