Translation via Google Translate:
I operate the "battery care" function and it does not activate
Is there any method for it to work?
Acciono la funfunc de "cuidado con la batería" y no se activa
¿Hay algunametodoa para que funcione?
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Battery care takes some time to learn your charging habits:
"About 1-2 weeks is right, but it will be more accurate if your schedule is quite consistent. So if you always plug it in at roughly the same times every day it will learn quicker than if you charge it sporadically."
