Battery capacity question XZ2
bondue
The phone is advertised to have 3180mAh but android is reporting 3060mAh.
Are Sony advertising the nominal capacity? Am I just unlucky to get a battery that is "within tolerance"?
I'm using aida64 to read out this information.
It feels a bit meh to get a brand new phone that already has less battery than advertised...
profile.country.US.title
Qatrium
@bondue
Check the battery capacity from the service menu for more accurate reading. You can access that menu by dialling the code *#*#7378423#*#*
3 REPLIES 3
Qatrium
@bondue
bondue
Thank you Slightly_smiling_Face it would seem that the 3180 Sony advertises is minimum, according to the menu you gave me a got a readout of 3200mAh ish.
Much appreciated!
Haldi4803
Service menu, service tests, battery health test?Screenshot_20180603-143023.png
 Does this show the current or max capacity?
