Audio problems
JACKDANIELSCBA
Audio problems
Hola estoy escuchando música en mis parlantes en mi dispositivo pero el volumen se baja automáticamente por cuestiones de seguridad para no dañar mi oído estoy cansado de que siempre me esté advirtiendo sobre el uso del volumen no me deja escuchar bien la música y tengo que estar cada tanto dandole aceptar a la advertencia ⚠ sobre el volumen alto para poder escuchar bien la música ¿hay alguna solución?
Hi I am listening to music on my speakers on my device but the volume is automatically downloaded for security reasons so as not to damage my hearing I am tired of being always warning me about the use of the volume, it does not let me listen well to the music and I have to be every so much giving you to accept the warning ⚠ about the high volume to be able to listen well to the music is there any solution?
-GT
Jonas
Hi @JACKDANIELSCBA, welcome to our forum.
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
The European standard EN 50332-2 specifies the sound level limits for combinations of headphones and personal music players (PMOs) such as smartphones or tablets. Some of the features of EN 50332-2 are:
  • The maximum output from the PMP and headphones must not be greater than 100 dB.
  • The user must be actively warned if the sound pressure level exceeds 85 dB for more than 20 hours per week. On Xperia™ devices, a pop-up warning will appear on the screen.
The safety caution can't be turned off, and in Sony Mobile's implementation it affects both wired accessories and connected Bluetooth® accessories.
I hope that answers your question!
